LACP between IOS XR router and QFX switch
Saskiaaa
Hello everyone,
im planning to config a LACP between XR Router and QFX switch. My questions
1- is my LACP connection is correct or the MUX  state must be ATTACHED  not DISTRIBUTING ?
2- how i can config  ip address  ( Gateway ) for the aggregated Interface  on XR Router?
QFX Switch  Configurations and Details:
set chassis aggregated-devices ethernet device-count 1
set interfaces ae0 aggregated-ether-options lacp active
set interfaces ae0 aggregated-ether-options lacp periodic fast
set interfaces ae0 unit 0 family ethernet-switching interface-mode access
set interfaces xe-0/0/4 ether-options 802.3ad ae0
set interfaces xe-0/0/5 ether-options 802.3ad ae0
root@right-sw02# run show lacp interfaces
Aggregated interface: ae0
    LACP state:       Role   Exp   Def  Dist  Col  Syn  Aggr  Timeout  Activity
      xe-0/0/4       Actor    No    No   Yes  Yes  Yes   Yes     Fast    Active
      xe-0/0/4     Partner    No    No   Yes  Yes  Yes   Yes     Slow    Active
      xe-0/0/5       Actor    No    No   Yes  Yes  Yes   Yes     Fast    Active
      xe-0/0/5     Partner    No    No   Yes  Yes  Yes   Yes     Slow    Active
    LACP protocol:        Receive State  Transmit State          Mux State
      xe-0/0/4                  Current   Slow periodic Collecting distributing
      xe-0/0/5                  Current   Slow periodic Collecting distributing
XR Router  Configurations and Details:
interface Bundle-Ether200
ipv4 address 10.100.28.1 255.255.255.
interface GigabitEthernet0/0/0/4
bundle id 200 mode active
interface GigabitEthernet0/0/0/5
:cisco2#show lacp bundle-ether 200
Bundle-Ether200
  Port          (rate)  State    Port ID       Key    System ID
Local
  Gi0/0/0/4         1s  ascdA--- 0x8000,0x0002 0x00c8 0x8000,00-05-32-78-98-37
   Partner         30s  ascdAF-- 0x007f,0x0001 0x0001 0x007f,02-05-86-71-fb-00
  Gi0/0/0/5         1s  ascdA--- 0x8000,0x0001 0x00c8 0x8000,00-05-32-78-98-37
   Partner         30s  ascdAF-- 0x007f,0x0002 0x0001 0x007f,02-05-86-71-fb-00
  Port                  Receive    Period Selection  Mux       A Churn P Churn
Local
  Gi0/0/0/4             Current    Fast   Selected   Distrib   None    None
  Gi0/0/0/5             Current    Fast   Selected   Distrib   None    None
Giuseppe Larosa
Hello @Saskiaaa ,
on the QFX switch you have used Fast LACP timers , on the XR side they are slow I think this is the only fix you need
and
Hope to help
Giuseppe
Hello @Giuseppe Larosa,
thank you for your replay, i have already configured the periodic fast on FQX, but sometimes display slow and sometime fast
for set ip address  ( gateway ) on XR, its  so correct?
Hello @Saskiaaa ,
the configuration of the Bundle-ether200 is correct on the XR side
Hope to help
Giuseppe
