LACP on ISR4461
Xiao Guai
Can use LACP on ISR4461?
Christopher Hart
Hello!
ISR 4000 series routers do support LACP (at least on relatively modern IOS-XE software). Here is an example from my lab with an ISR 4331 router running IOS-XE 16.09.04 connected to a Catalyst 3850 switch using an LACP port-channel.
Router#show platform
Chassis type: ISR4331/K9
Slot      Type                State                 Insert time (ago)
0         ISR4331/K9          ok                    6w2d
 0/0      ISR4331-3x1GE       ok                    6w2d
 0/1      NIM-ES2-8           ok                    6w2d
1         ISR4331/K9          ok                    6w2d
 1/0      UCS-E160S-M3/K9     ok                    6w2d
R0        ISR4331/K9          ok, active            6w2d
F0        ISR4331/K9          ok, active            6w2d
P0        PWR-4330-AC         ok                    6w2d
P2        ACS-4330-FANASSY    ok                    6w2d
Slot      CPLD Version        Firmware Version
0         17100927            16.12(2r)
1         17100927            16.12(2r)
R0        17100927            16.12(2r)
F0        17100927            16.12(2r)
Router#show version | include IOS XE
Cisco IOS XE Software, Version 16.09.04
Router#show etherchannel summary
Flags:  D - down        P/bndl - bundled in port-channel
        I - stand-alone s/susp - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1       Po1(RU)         LACP     Gi0/0/1(bndl) Gi0/0/2(bndl)
RU - L3 port-channel UP State
SU - L2 port-channel UP state
P/bndl -  Bundled
S/susp  - Suspended
Router#show running-config interface GigabitEthernet0/0/1
Building configuration...
Current configuration : 154 bytes
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 negotiation auto
 channel-group 1 mode active
end
Router#show running-config interface GigabitEthernet0/0/2
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 negotiation auto
end
Router#show running-config interface Port-channel1
Current configuration : 156 bytes
 description To Switch
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no negotiation auto
end
I hope this helps - thank you!
-Christopher
5 Replies 5
marce1000
 - Seems you can , try (out) the commands mentioned in this document : https://thenetworkstack.com/new-cisco-isr4000-series-routers/
 M.
I read this before in one of CiscoLive
ISR not support LACP
ISR 4K's definitely support LACP.
Christopher Hart
Hello!
        d - default port
P/bndl -  Bundled
S/susp  - Suspended
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 negotiation auto
end
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 negotiation auto
end
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no negotiation auto
end
-Christopher
thanks for confirm my answer.
