08-15-2012 02:33 AM - edited 03-04-2019 05:16 PM
Hi i have this situation.
I have EPL on my MPLS.
Our are cisco stacks.
and routers are ISP provider and i don't have any chance doing with them.
I don't know how much routers are on the way
In the one DC is 3750X stack on the other DC is 3750X stack between them is LACP protocol.But if the line is break on the way i don't shutdown on my cisco stack and i must wait 1,5minutes then LACP detect broke line and redirect traffic to the other line.
On the 3750X is impossible change LACP timeout.
I think that the solution is IP SLA and ICMP responder between mgmt ip adresss and shutdown interface.But the ICMP traffic go across one line based on hash.
Do you have Any idea?I know the solution is STP but it is the last chance
08-15-2012 05:17 AM
Are you running etherchannel? You coudl for example configure Flex links
Or a routing protocol, all these guarantee fast convergence. But Not IP SLA.
08-17-2012 01:03 AM
thank you i try Flex Links, but it doesn't work.CDP it works, but no ICMP or other traffic
Routing protocol is imposible it must be L2
And is it configuration correct?
Stack1 (one Data center)
interface GigabitEthernet1/0/10
description ***Trunk to SCVK***
switchport mode trunk
switchport backup interface Gi2/0/10
interface GigabitEthernet2/0/10
Stack2 (other data center)
Configuration without change ?
Configuration Flex link is only on one stack?
With this configuration i Have this
vvlansw51 Gig 2/0/10 132 S I WS-C3750X Gig 1/1/1
vvlansw51 Gig 1/0/10 162 S I WS-C3750X Gig 2/1/1
vvlansw06#sh interfaces switchport backup detail
Switch Backup Interface Pairs:
Active Interface Backup Interface State
GigabitEthernet1/0/10 GigabitEthernet2/0/10 Active Up/Backup Standby
Preemption Mode : off
Multicast Fast Convergence : Off
Bandwidth : 1000000 Kbit (Gi1/0/10), 1000000 Kbit (Gi2/0/10)
Mac Address Move Update Vlan : auto
But on the other switch i have this
vvlansw51#sh spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32769
Address 0007.ec01.4480
Cost 4
Port 49 (GigabitEthernet1/1/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 649e.f3ce.e200
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/1/1 Root FWD 4 128.49 P2p
Gi2/1/1 Altn BLK 4 128.103 P2p
