LAN route is not showing on Roting table, on SPOKE using EIGRP
prabinchand
Hello experts!
i am doing DMVPN but the problem here is : NPJ-router is not getting the route for SERVER-AREA-DR loopback.
hence HO-router is getting both route for LAN network from NPJ & SERVER-AREA-DR loopback.
can say, NPJ & SERVER-AREA-DR are not getting each other LAN network route.
NOTE: topology is attached below
CONFIGURATION
HO
hostname HO
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
lifetime 2500
crypto isakmp key DMVPN address 0.0.0.0
crypto ipsec transform-set DMVPN esp-3des esp-md5-hmac
mode tunnel
crypto ipsec profile DMVPN-PROF
set security-association lifetime seconds 2500
set transform-set DMVPN
interface Tunnel1
ip address 50.50.50.1 255.255.255.248
no ip redirects
ip nhrp authentication SECURE
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp redirect
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 123456
tunnel protection ipsec profile DMVPN-PROF
interface FastEthernet0/0
description ***WAN-SIDE***
ip address 172.16.10.1 255.255.255.248
speed auto
duplex auto
interface FastEthernet0/1
description ***LAN-SIDE***
ip address 192.168.10.1 255.255.255.0
speed auto
duplex auto
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
router eigrp 100
network 50.50.50.0 0.0.0.7
network 192.168.10.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
NPJ
hostname NPJ
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr 3des
hash md5
lifetime 2500
crypto isakmp key DMVPN address 172.16.10.1
crypto isakmp key DMVPN address 172.16.10.3
mode tunnel
interface Tunnel1
ip address 50.50.50.2 255.255.255.248
no ip redirects
ip nhrp map multicast 172.16.10.1
ip nhrp map 50.50.50.1 172.16.10.1
ip nhrp nhs 50.50.50.1
ip nhrp shortcut
tunnel key 123456
ip address 172.16.10.2 255.255.255.248
speed auto
duplex auto
ip address 192.168.20.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router eigrp 100
network 192.168.20.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
SERVER-AREA-DR
hostname SERVER-AREA-DR
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr 3des
hash md5
lifetime 2500
crypto isakmp key DMVPN address 172.16.10.2
mode tunnel
interface Loopback1
description ***lets-say LAN***
ip address 192.168.100.100 255.255.255.255
interface Tunnel1
ip address 50.50.50.3 255.255.255.248
no ip redirects
ip nhrp shortcut
tunnel key 123456
ip address 172.16.10.3 255.255.255.248
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router eigrp 100
network 192.168.100.100 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
No ip next-hop-self eigrp x
No ip split horizon eigrp x
This need in hub only
5 Replies 5
Thank you so much sir, it worked.
Will you please clearify me the uses of this two command, why we use it? what happens if not used??
balaji.bandi
check this may help you : EIGRP split horizon
https://packetlife.net/blog/2008/nov/03/disabling-split-horizon/
BB
