10-01-2012 09:55 AM - edited 03-04-2019 05:43 PM
people!!!!!!!, i am under pressure please help me out, if i ping or traceroute my other network using my router its working, but if i do it using a computer its only ending on my LAN facing interface, i have no access-list configured, i am using open tunnels, i set the ip route 0.0.0.0 0.0.0.0 tunnel 7, where am i lost, from my router i can see all my other LANs but i cant access them using a computer. i can traceroute 8.8.8.8 using a router but with my computer i cant access google,
please help!!!!!!!!!!!!!!!!!!!
Solved! Go to Solution.
10-01-2012 12:48 PM
Its look like your router need NAT configuration,
Please try this if its help.
int vlan 1 (or your internal interface)
ip nat inside
int fas1
WAN interface
ip nat outside
access-list 1 permit 172.16.1.0 0.0.0.255 (your internal subnet )
ip nat inside source list 1 interface t7 overload
please check this link for more detail.
http://serverfault.com/questions/287817/configure-cisco-router-overload-nat-ios-15
please rate if this helps.
thanks
10-01-2012 10:01 AM
8.8.8.8 is a public IP so you need to go to internet to communicate with it and if your PC has got a private address then you must do NAT overload on the router.
Post your config.
Regards.
Alain
10-01-2012 12:48 PM
ip nat inside
int fas1
WAN interface
ip nat outside
thanks
10-07-2012 10:48 PM
Thank you very much it has worked fine, that was excellent
