Port 80 not Forwarding
libertysv
please help me out, i am trying to forward port 80 to my web server but its not working, if i ping my website its replying, but if itry to access it from the browser its not working
Hello
To configure  your Cisco router  to do  Port forwarding to your web server you will need to do the following
IP nat inside Source static tcp  "your privet IP address" " Public IP Address "  80  extendable
The above command will do the  NAT port forward  but you will need to add  ACL.
Access-list 171 permit tcp any host “Public IP Address " eq 80
And case it was HTTPs you will use 443 instead of port 80 .
Hope it will help
cadet alain
from where are you trying this? what is the forwarding device, a router or firewall ?
are you sure your server is listening on port 80 ? are there any ACL or firewalling feature in place ?
Post your configs as well as the screenshots of your test.
Regards.
Alain
Hello
Hope it will help
Thank you very much it has worked fine, that was excellent
