large size ospf design over MPLS WAN
veenarani2312
Hi Guys
if I have a wan with say 100 routers on an MPLS network using gre tunnels and using OSPF, how would you recommend the design, would you just put the whole lot in area 0?
what if there were more routers?
if not what other options would there be?
cheers
balaji.bandi
This is again depends on requirement ? why they need to be all in Area 0 ? can they split in to different areas due to some limitations and also in terms of LSA flooding and hard to maintain, troubleshooting
This what cisco suggested :
https://www.ciscopress.com/articles/article.asp?p=1763921&seqNum=6#:~:text=Current%20ISP%20experience%20and%20Cisco,is%20the%20most%20optimal%20design.
BB
As my knowledge all within area 0 which is called super backbone, this make all CE (PE-CE ospf ) connect to Super backbone Area 0.
