Last input 4w1d (Help)
bagvanliju
Hai,
Seems to be starnge to me.The below mentioned link was down for a while and came up after some R&D,But the last input showing still 4w1d(Last input 4w1d) link is stable and traffic is there in the link .I cleared the interface counters..but its not reflecting ..any other way to clear this ...
Thanks in advance
below is the interface status captured
BLR-ISP-ACC-SWH-XX>sh int FastEthernet1/0/14
FastEthernet1/0/14 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001f.26a0.9310 (bia 001f.26a0.9310)
Description: #XX#XXX-ISP-XXX#
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 7/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 4w1d, output 00:00:09, output hang never
Last clearing of "show interface" counters 00:15:53
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 629000 bits/sec, 479 packets/sec
5 minute output rate 2942000 bits/sec, 590 packets/sec
477748 packets input, 83698925 bytes, 0 no buffer
Received 2 broadcasts (0 multicasts)
0 watchdog, 2 multicast, 0 pause input
584876 packets output, 372182385 bytes, 0 underruns
BLR-ISP-ACC-SWH-XX>>p XX.XX.XX.XX
Sending 5, 100-byte ICMP Echos to XX.XX.XX.XX, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/11/17 ms
ujil
satish_zanjurne
Level 4
Level 4
hi,
1.See if by shutting down & no shut interface , whether it is reflecting the input time.
2.Otherwise it seems to be IOS bug,
HTH...rate if helpful..
Hi Satish,
Thanks for the reply.shut and no shut has been done but the same status ......
Description: ##
reliability 255/255, txload 5/255, rxload 1/255
Last input 4w2d, output 00:00:05, output hang never
Last clearing of "show interface" counters 02:51:54
5 minute input rate 477000 bits/sec, 367 packets/sec
5 minute output rate 2138000 bits/sec, 465 packets/sec
5977273 packets input, 1161930391 bytes, 0 no buffer
Received 17 broadcasts (0 multicasts)
0 watchdog, 17 multicast, 0 pause input
7105290 packets output, 3682287543 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
BLR-ISP-ACC-SWH-XX>s log
Syslog logging: enabled (0 messages dropped, 1
Log Buffer (4096 bytes):
423630: Nov 20 13:38:02.362 IST: %LINK-5-CHANGED: Interface FastEthernet1/0/14,
changed state to administratively down
423631: Nov 20 13:38:04.652 IST: %LINK-3-UPDOWN: Interface FastEthernet1/0/14, c
hanged state to up
423632: Nov 20 13:38:09.912 IST: %SYS-5-CONFIG_I: Configured from console by 224
71ansh on vty1 ()
BLR-ISP-ACC-SWH-XX>p XX.XX.XX.XX
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/9 ms
Checked another interface in the same Core router showing lastinput (Below mentiond) ..
BLR-ISP-ACC-SWH-XX>s int FastEthernet1/0/23
FastEthernet1/0/23 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001f.26a0.9344 (bia 001f.26a0.9344)
Description: #XX##
Internet address is XX.XX.XX.XX
Last input 00:00:49, output 00:00:08,
Link is not having any issue its working perfectly ..but just a curiosity to know what could be the issue
ujil
