layer 2 and layer 3 vpn
dannymcca
i am trying to set up a vpn that will pass both layer 2 and layer 3 traffic.
i have 2 887VA routers and these communicate via adsl lines. They are currently passing layer 3 traffic without any issues and i have used an IPSEC-ISAKMP security.
It has been some years since i did my CCNA and am therefore very rusty and would appreciate as much help as you can give.
Many thanks
Jeff Van Houten
Level 5
Level 5
You might want to look at l2tp instead of IPSec.
i have looked for a sample l2tp configuration but most use pppoe whereas my connection is over adsl using ppoa.
i currently have a working vpn using ipsec/isakmp is there a simply way to enable this to use l2tp protocol?
my current config is attached.
thanks for your help.
