Layer 2 switching to DR site
luthierone
I have a dr/colo site with a 50 meg fiber connection back to our office. We had to make it an extension of our existing layer 2 network because of limitations of particular server products. So basically we have a switch at each side that switches layer 2 traffic to and from the colo. we also have a 6 meg internet connection that we wanted to incorporate into the mix for redundancy and load-balancing. I used linux and openvpn to accomplish transporting layer 2 traffic across the internet. So we have 2 connections to our dr site: 50 meg fiber and 6 meg multi frame and the solution works beautifully from a fail over standpoint. However, we would like to load balance traffic over the two so that our 6 meg isn't just sitting idle all day. Is there any way to accomplish this even though its just a layer 2 network?
Any input would be appreciated.
Hello luthier,
you can take advantage of per vlan STP if you are using multiple VLANs you can make a path preferred for one vlan and the other for another VLAN but this is not true load balancing is a way to use both physical links.
I don't know if this applies to your case
Giuseppe
6 Replies 6
sivakondalarao
Please provide your complete network diagram.
regards
skrao
Here it is. Thanks.
Any ideas or info that I could be pointed to?
I have it set and I'm just using stp for now...but that wastes the other link. Is this something I could use:
http://www.cisco.com/warp/public/473/15.html
Hello luthier,
Giuseppe
OK thanks.
