Layer 3 from vlan to port
admin28373
I am trying to get my head around layer 3 switch routing and am missing the link between vlans and ports.
I'm configuring layer 3 with SVIs.
My switch is an SG250-08HP.  I have exec  IP routing.
I have added a vlan 10,20 with no shutdown and the switches GE1 ingress to the router set with tagged 1,10,20
So executed.
interface vlan 10
name Office
no shutdown
ip address 192.168.10.4 255.255.255.0
interface vlan 20
name Geek
no shutdown
ip address 192.168.20.4 255.255.255.0
I have an Access port interface that is an SVI as no switchport.
interface GigabitEthernet6
no switchport
But how does this port get the association with the intended vlan, say 20?
16 Replies 16
@balaji.bandi
This is a good example of what I mean with the timestamps. You post the exact same information I did earlier, which can only mean that my post was not visible to you when you posted your reply.
I may be thinking that - while i was in reply the post - you may be doing the same time you reply too another side, so when we addressing reply to OP, we may not see each other reply until we press reply.
BB
