Layer2 bridging on routed interface on ASR1001-X
pknudsen
Hi all.
I have tried to do some bridging on a ASR1001-X with no luck so far.
I have done this may times before on ISR-G2 routers with great success, but now I have to do it on a ASR1001-X router.
The setup consist in simple terms of a ASR1001-X router with a WAN port (Gi0/0/2) toward ISP backbone/MPLS and LAN port (Gi0/0/1) toward ASA5508X in untagged mode.
The router is allready running several layer 3 circuits on the WAN port for several MPLS connections - and now I want add one more vlan on my WAN port for internet use - but I don't want my ASR1001-X to be exposed on the internet with a layer 3 IP address, so a layer 2 bridging seems to be the perfect solution for me.
So i now have one more VLAN on my WAN trunkport (Gi0/0/2) - and want to bridged all traffic from this WAN Vlan toward a untagged LAN port (Gi0/0/1) - and having the folowing config so far - but so far with no luck...
bridge irb   <-- Not sure about this is needed.
! LAN interface - Untagged toward outside interface on ASA5508X
interface GigabitEthernet0/0/1
 service instance 50 ethernet
  encapsulation untagged
  bridge-domain 50
! WAN interface
interface GigabitEthernet0/0/2
  encapsulation dot1q <Vlan-ID>
  bridge-domain 50
end
So the question is: what am I missing, or do I have done som wrong config for now...?
Peter Paluch
I believe that the main reason why your configuration does not work is the lack of tag manipulation. You are receiving frames with VLAN50 on Gi0/0/2 but in order to forward them out Gi0/0/1, then need to be untagged - and vice versa.
Try this configuration instead - it uses a more recent configuration style which is going to be maintained in newer IOS-XE versions:
  encapsulation dot1q 50
  rewrite ingress tag pop 1 symmetric
bridge-domain 1
 member GigabitEthernet0/0/1 service-instance 50
 member GigabitEthernet0/0/2 service-instance 50
Best regards,
Peter
7 Replies 7
Peter Paluch
bridge-domain 1
Best regards,
Peter
Hi Peter
Thanx a lot for the quick answer - I have now tested with your config - and bidging is now working - Perfect..!
Preben Knudsen
Hi Preben,
It has been a pleasure :)
Best regards,
Peter
Hi Peter.. thanks for a great explanation...
I have a similar situation which is depicted below. We have a link that terminates WAN connection from our WAN provider from various offices and 3rd parties (using unique dot1q tags) on Gi0/0/0 (and Gi0/0/2 not shown here) . I have created sub-interfaces for the office vlans on the ASR Gi0/0/0 interface; however for 3rd parties I would like Layer3 to terminate on the firewall and the ASR to serve as purely an L2 device
For the purpose of understanding, lets assume 3rd party VLAN in question is 1417
WAN -------(Gi0/0/0) ASR (Gi0/0/3)-------- (Access) SWITCH (802.1q Trunk)--------- Firewall
The switch access port will be in vlan 1417 and the trunk b/w the switch and firewall will carry that vlan too with sub-interfaces created on the firewall as well
Can you please confirm if the above design is valid and if so also review the ASR configuration ?
interface GigabitEthernet0/0/0
 service instance 1 ethernet
 encapsulation dot1q 1417
interface GigabitEthernet0/0/3
bridge-domain 1
member GigabitEthernet0/0/0 service-instance 1
member GigabitEthernet0/0/3 service-instance 1
iswift
Hello Peter
Do you have info on what versions of IOS-XE this applies to ?
Is there a feature-set needed ?
With an ASR1001-X, universal image 03.16.02.S.155-3.S2
there is no member command under the bridge-domain config section; the only avail options are :-
Bridge-domain mode commands:
  default   Set a command to its defaults
  exit      Leave the bridge-domain configuration submode
  ip        IP related commands
  mac       MAC Address related commands
  no        Negate a command or set its defaults
  shutdown  Take the bridge domain admin down
I am able to use the bridge-domain definition in the service-instance section, on each interface though.
My problem is a bit like the original poster, is that my 'outside' is a dot1q encap sub-interface from the carrier. (In the UK an Etherway bearer can carry multiple 'Etherflows', each one dot1q tagged from the carrier, and I need to bridge one).
Under the sub-interface you cannot select either the service-instance, or the bridge domain command itself;
ever-dcr-r01(config-subif)#bridge?
% Unrecognized command
ever-dcr-r01(config-subif)#serv?
service-policy  service-routing
Ian
Hi Ian
You have to do all bridge commands under the main interface - NOT under subinterfaces due to the fact these is only for layer 3  functions. You could have many service instances under the main interface as well.
It might be sonthing like:
bridge-domain 50
 member GigabitEthernet0/0/<xx> service-instance 50
 description ** WAN interface **
 no ip address
  description ** bridged vlan **
interface GigabitEthernet0/0/2.101
 description ** WAN - Layer 3 interface **
 encapsulation dot1Q 101
 ip address 172.16.aa.aa 255.255.255.252
interface GigabitEthernet0/0/2.102
 encapsulation dot1Q 102
 ip address 172.16.bb.bb 255.255.255.252
And please rember the bridge-domain is in global config - please remember there is 2 bridge commands in global: use the "bridge-domain", and NOT the "bridge" command.
Preben Knudsen
Great reply, thanks v much.
I still have the problem that I have no 'member' command under the global bridge-domain command.
r01(config-bdomain)#?
So I have used the dridge-domain command un der the service instance config on both interfaces.
This is what I look like now :-
bridge-domain 1
 description *** L2 Connection to ddd ***
 no ip address
 negotiation auto
 service-policy output VoIP
 service instance 10 ethernet
  description *Bridged SIP link *
  encapsulation dot1q 4093
  bridge-domain 1
interface GigabitEthernet0/0/4
 description *** L2 Connection to Mitel SIP Gateway ***
 no ip address
 no logging event link-status
 load-interval 30
 shutdown
 negotiation auto
 no snmp trap link-status
  bridge-domain 1
r01#sh bridge-dom 1
Bridge-domain 1 (2 ports in all)
State: UP                    Mac learning: Enabled
Aging-Timer: 300 second(s)
    GigabitEthernet0/0/0 service instance 10
    GigabitEthernet0/0/4 service instance 10
   AED MAC address    Policy  Tag       Age  Pseudoport
