Leased Line link error and bandwidth check
siddindia
I'm implementing a WAN on leased line.Service provider of leased line always says thier lines are ok, but actually i faced problem with link.
Can anyone tell how can i check link error and bandwith currentely getting from service provider through ROUTER.
Siddhartha
Giuseppe Larosa
Hello Siddharta,
the first basic check is to use
sh interface serial x/y
command and to see if there are errors of any type.
Repeat the commands every 5 minutes to see if error counters are incrementing.
Here it is a link for serial lines troubleshooting
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1915.html
possibly compare the outputs of routers at both ends of the link.
Hope to help
Giuseppe
