09-30-2024 04:57 AM
Hi All
I am looking to purchase some 8300 routers with no licence limitations and also the HSEC licences.
I have read the below but I'm a little confused.
Cisco Catalyst 8300/8200 Series Edge Platforms Ordering Guide - Cisco
Will we need to renew the DNA licences after 7 years to keep using the product and will the said features automatically stop after 7 years if not renewed?
Many thanks
09-30-2024 05:05 AM
If you purchased essential License, then that Router work as expected after 7 years, any additional feature may have compliance issue since you do not have active contract or License with cisco.
check some FAQ :
09-30-2024 05:33 AM
Hello!
With catayst routers if you don't extend the DNA licences the router will continue to work as normally but you will loose the functions of SD-WAN + cisco might start throttling your cryto speed based on the tiering.
BR
