License of C8300
ruch
I'm preparing
C8300-1N1S-6T BOM to replace 3954-VSEC-K9
router. It has Cisco
3945E
Voice Sec Bundle,
PVDM3-64, UC&SEC Lic,FL-CUBE10
I'm bit confused as how to VSEC license for C8300 router? Do i need to add
DNA-P-T2-A-3Y
license of
L-DNA-C8300
license or it come by default when i select PVMD modules?
M02@rt37
Hello @ruch,
The Cisco 8300 Series routers, including the
C8300-1N1S-6T
follow a different licensing model compared to older routers like the 3900 Series. The concept of a VSEC (Voice Security) license doesn't directly apply to the Cisco 8300 Series.
To enable features related to voice and security on the Cisco 8300 router, you'll need DNA licence.
DNA-P-T2-A-3Y
is a three year licence support.
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.cisco.com/c/dam/m/en_us/products/software/dna-software/dna-software-sd-wan-routing-matrix/pdf/Cisco_DNA_Software_SD-WAN_and_Routing_Matrices.pdf&ved=2ahUKEwjoxtfgzZuCAxX5Y6...
Best regards
M02@rt37
Hello @ruch,
C8300-1N1S-6T
DNA-P-T2-A-3Y
Best regards
ruch
Hi M02@rt37
Thank you very much for the response. I will add the necessary license. This license is based on the bandwidth right
You're so welcome.
Best regards
