Licenses for ISR4331
ibrkic001
Hello.  i have two routers ISR 4331, and on smart account i have two licenses  ISR_4331_Security
Can i register devices on classic way with call-home, or must wit specific license reservation?
Best regards
balaji.bandi
No. you will not get any txt file for License
Smart License mean,you need to connect this device some how (using proxy or open FW rule for Cisco License site with port 443) to register License.
thanks for pointing i have provided different URL in the old post.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/smart-licensing/qsg/b_Smart_Licensing_QuickStart/b_Smart_Licensing_QuickStart_chapter_00.html
BB
I did not find answer in the document.
From routers . i have got alarm :
%SMART_LIC-4-RESERVE_IN_PROGRESS: None License Reservation process must be completed with the 'license smart reservation install' command. Reservation started on May 26 10:19:54 2020 CET
Just wondering, is there necessary to activate license with SLR, Authorization code ( txt file) or that can be on classic way, with id token from CSSM on prem.
This is output from show license summary:
Smart Licensing is ENABLED
Registration:
Status: UNREGISTERED
Export-Controlled Functionality: NOT ALLOWED
License Authorization:
Status: EVAL MODE
Evaluation Period Remaining: 49 days, 0 hours, 34 minutes, 21 seconds
License Usage:
License Entitlement tag Count Status
(ISR_4331_Security) 1 EVAL MODE
balaji.bandi
BB
