Limit max calls based on DNIS on the PRI line
t4tauseef33
I have the PRI line which has few DDI numbers. Is there any way that i could restrict the max number of simultaneous calls to the called DDI number?
lets say if the ddi number is ****123654 limit it to 5 calls. so max 5 concurrent calls can be landed to this number and the sixth call fail.
username DDI_Number user_maxlinks (number of connections)
I have tried the above command but its not working.
Can you please help me out?
6 Replies 6
paolo bevilacqua
What router is that and which IOS version ?
Sorry about missing this information
Its 5400XM dial rack with IOS version Version 12.4(25a),
Check:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094898.shtml
Please remember to rate useful posts clicking on the stars below.
HI,
I have the following config on 5400XM. Can you please tell me where and how can i implement the ' called-number 5557528 max-conn 3' command? I have few other Profiles on the 5400Xm same like below. modem-pool command is not available in AS5400Xm and AS5350Xm. Please help me out.
resource-pool group resource Profile-1
range port 1/0 1/59
resource-pool profile customer Profile-1
limit base-size 60
limit overflow-size 0
resource Profile-1 speech
dnis group DNIS-Profile-1
interface Group-Async0
ip unnumbered Loopback0
encapsulation ppp
async mode interactive
peer default ip address pool IPPOOL
ppp authentication chap pap callin
group-range 1/00 1/59
line 1/00 1/59
no motd-banner
no exec-banner
exec-timeout 0 0
no flush-at-activation
no vacant-message
modem InOut
modem autoconfigure type MODEMCAP
autocommand  telnet 192.168.168.2 /stream
no activation-character
transport input all
escape-character NONE
autoselect during-login
autoselect ppp
autohangup
Search with the box above to see if the command has changed and how.
The command seems to be there but seems not acceptable when you have resource pools enabled. Is there any way i can accomplish this with the configuration i have provided above. It should be very simple but don't know how to do it.
