Is it possible to encrypt data between ISDN connection?
yaminqureshi
Is it possible to secure the data transfer between ISDN connection using encryption algorithms or some other way with cisco routers at both end?
Yamin
paolo bevilacqua
Are you the end user ?
Your network consultant should be able to explain you the ipsec technology.
