Limiting bandwidth in GRE Tunnel
scottdimmick
We have two Cisco 2811 Routers setup with a GRE tunnel that we would like to constrain the bandwidth on to replicate a
satellite connectinon of 400 kbits. We tried the bandwidth command 400, but from what I understand that is only for routing metrics and not actual speed of the interface. Any suggestions?
Thanks!
5 Replies 5
Richard Burts
Scott
You are correct that setting the bandwidth in the tunnel interface is for routing metrics (and perhaps network monitoring utilization reports) and does not change the physical performance of the tunnel. You might consider configuring traffic shaping on the physical interface where the tunnel is terminated. With shaping you can constrain the traffic to a specified capacity.
Rick
Rick
Rick,
We are also running EIGRP over the tunnel, would this cause any issues?
Scott
It depends. If the tunnel is configured with a high bandwidth and you use shaping to constrain the traffic to a low rate it is possible that EIGRP could be impacted (though I think it is not very likely). The issue is that by default EIGRP will try to use up to 50% of the configured bandwidth for its updates. If there is a big mismatch then EIGRP might be impacted.
The safe thing to do is to configure a bandwidth on the tunnel that represents the capacity that is actually going to be available.
Rick
Rick
relsethagen
Why not do an MQC shaping policy outbound from both tunnel endpoints to shape the traffic on the tunnel interface.Here is an example
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a008017405e.shtml
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As the other posters have noted, a shaper might be used to replicate your satellite bandwidth.  However, one aspect of satellite behavior that would be difficult to replicate on 2811 router, would be the high latency.  If you need to replicate that too, you'll likely need an external "appliance" to delay your traffic.  (Such appliances can might also emulate lower bandwidth and/or packet loss too.)
