limiting number of sessions
krishna3010
hi
we can login to a cisco device with username and password when we give login local in line vty mode. can someone say me how to limit the number of sessions a user can have. when i try one user can use all vty sessions. is there any way to configure that one user gets one session only
mrdogantr
     You are use configuration below for only one concurrent connection.
line vty 0
login local
line vty 1 4
no login
hth
Muammer
hi, dogan,
if i give that way only one session will be activated. i have multiple users . everyone should be able to login simultaneously with different usernames and passwords. but a person should not be able to login with the same username and password multiple times simultaneously
You can try  "user-maxlinks".
username xx  user-maxlinks 1  password yy
hth
Muammer
