cisco 1921 router boot issue
zeuscyril
Level 4
Level 4
hi all,
i purchased 1921 with ipbase license , then i installed security 60 days trial license in it.the license is showing active but not in use
and in the sh version also is not showing.
then i used some command like boot using security bundle then i restarted the router , after that i am getting the following the message
"loadprog bad file magic number 0x0 boot cannot load flash"
then i tried to upload from tftpdnld using rommon mode then i am getting following error
"Interface GE 0 link down TFTP: Operation terminated prematurely in rommon mode"
plz provide me the solution. th ios version is " c1900-universalk9-mz.SPA.151-3.T1.bin"
thnaks
cyril
Leo Laohoo
Hi Cyril,
The IOS may be corrupt.  Eject the CF and copy the correct IOS using a multi-card reader that can support Compact Flash.
fabios
Level 3
Level 3
Sorry for being approximative here but I have limited access at the moment.
You should try in rom mon to set the configuration register to the value that ignores the configuration.
you can look it up searching for password recovery and then reload the router.
If the router boots then do a write erase and reconfigure. If not .... You might have messed up the licensing and the image on your router trying to activate the trial.
I am sorry but I do not have so much experience on the ISR2 router licensing mechanics.
Fabio
