line protocol is down
The_guroo_2
Level 2
Level 2
one of my router line protocol is down....if the WAN speed is mismatch will line protocol goes down???? thanks
shivlu jain
Level 5
Level 5
Yes it happens because it is not abel to negociate with the neighbor.
regards
shivlu jain
rajesh1331
Hi..
make the following checks
1. check if remote router is powered on or if there is link failure
2. Check encapsulation at both ends.
3. check clock-rate
rgds
rajesh
