Link aggregation or Multipoint with different bandwidth links from two isps
shameer sa
Hi ,
I have a 100 mbps leased line from ISP1 and 50 mbps from  ISP 2 between two offices .That means A and B location of both the leased lines are same.
My question is it possible to Linkaggregate or multipoint (multi link ppp) these lines for a total throughput of 150 mbps . My doubt is regarding the different
bandwidth and how the packet will travel.
Note : I have all kind of devices ,router and l3 switches.
Links are private leased lines .
o2mac
sukesh tandon
hi shammer,
yes certainly you can do it. :)
If it possible how the packet will flow after 50 Mbps traffic.
Shameer,
Understand you want to bundle two unequal bandwidth links using a multilink. To my understanding technically it is feasible but the load will be shared equally on both the links irrespective of bandwidth. something similar to round robin between two links.
Sathvik K V
Shameer,
Found a solution of creating subinterfaces with frame relay in one of the discussion. Refer the below URL and see if this is useful.
https://supportforums.cisco.com/discussion/10738401/ppp-multilink-using-2-different-serials-different-bandwidth
Sathvik K V
