link fragmentation and interleaving for ethernet
Is there any LFI mechanism for ethernet networks?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
None that I'm aware of, as usually there's sufficient bandwidth, even with 10 Mbps, i.e. there's often no need to LFI.
Depending on your needs, you might reduce IP packets sizes by setting MTU or IP MTU down from Ethernet defaults (or don't use jumbos).
