Link Load sharing using application port numbers
dpugalendi.d
Dear Team,
I am having two - 4Mbps links connected to Location A to B ,  i would like to send Mail , Browsing and FTP traffic only via link 2 , and all other traffic via Link1 ,
The Router is Cisco2921 with Security IOS Enabled , Could you please suggest commands and documents reagarding the same
you don't need natting if you don't want to but I gave  you the most comprehensive config I could supposing you were natting traffic.
Alain.
6 Replies 6
cadet alain
You can use PBR to achieve what you want.
here is an example config:
int f0/0
description LAN interface
ip add 10.1.1.254 255.255.255.0
ip policy route-map POLICY-ROUTING
ip nat inside
no sh
int s0/0
description link1
ip add 192.168.1.254 255.255.255.0
ip nat outside
no sh
int s0/1
description link2
ip add 192.168.2.254 255.255.255.0
ip nat outside
no sh
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 100 permit tcp 10.1.1.0 0.0.0.255 any eq 25
access-list 100 permit tcp 10.1.1.0 0.0.0.255 any eq 80
access-list 100 permit tcp 10.1.1.0 0.0.0.255 any eq 21
access-list 100 permit tcp 10.1.1.0 0.0.0.255 any eq 20
access-list 100 permit tcp 10.1.1.0 0.0.0.255 any eq 443
access-list 100 permit tcp 10.1.1.0 0.0.0.255 eq 20 any
access-list 100 permit tcp 10.1.1.0 0.0.0.255 eq 21 any
route-map NAT-LINK1 permit 10
match ip add 1
match interface s0/0
route-map NAT-LINK2 permit 20
match ip add 1
match interface s0/1
ip nat inside source route-map NAT-LINK1 interface s0/0 overload
ip nat inside source route-map NAT-LINK2 interface s0/1 overload
route-map POLICY-LINK1permit 10
match ip address 100
set interface s0/0
route-map POLICY-LINK2 permit 10
set interface s0/1
Regards.
Alain.
GREAT , mostly matching to my problem , but can you just explain me why we need NATTING on this ?
Alain.
One more clarification,
1 . Whether we need to apply this "ip policy route-map POLICY-ROUTING" in
only LAN interface ? or any other interface is possible ?
2. If only on LAN interface then , i can able to apply only one policy to
one interface , then my next policy for LINK2 ?
On Thu, Sep 8, 2011 at 5:09 PM, cadetalain <
1)PBR can only be applied inbound on the interface where the src packets are coming in or it can be used for router traffic with the ip local policy route-map command
2)All 2 policies are taken into account in the route map the 10 clause if for link1 traffic and the 20 clause matches all other traffic which will get to link2
Regards.
Alain.
shehinpm1
The scenario is very clear,for this requirement nating is not required,u have to do PBR in u r router if u r terminated those
2 links in your in router.in route-map classify only that perticular traffic which u send to link 2,other traffic wll go through
other ink bcoz policy based routing will take the action before routing protocol decision.
