Link on switches down in packet tracer
TheFox
I am doing an exercise in packet tracer where I configure Inter-VLAN routing for a router and stick topology. Everything seems to be configured. However, the link between two of my switches is consistently down, and I have no idea why.  Why is this happening?  I have attached the packet tracer file I am working on. The commands I entered are listed, as well as VLAN information.
you need to use a cross cable for the switch to switch connection. I have attached the revised lab file. The link between both switches can either be a trunk, or an access port (I used an access port in Vlan 4)...
Martin L
no file attached. you can find some examples of ROAS, aka inter-vlan routing in CLN. there are a lot of samples of PT, configs nad explanations.
I think my examples of ROAS are still in my documents (old files i haven't checked recently_
see https://learningnetwork.cisco.com/search.jspa?q=inter-vlan
https://learningnetwork.cisco.com/search.jspa?q=router+on+stick&type=document&author=%2Fpeople%2F63302
Sorry about that. The file is attached now.
Leo Laohoo
Wrong forum.
Please go to the Cisco Learning Network for assistance in your school work.
