Linking Keychain to ospf process
a.irizarry4738
Is there any way that we can link the Key Chain to the OSPF process?  I wanted to know if you can add a statement and the router sends it out to its OSPF neighbors?Routing
mkazam001
Level 3
Level 3
you can't configure key chains for ospf authentication, only below options allowed:
plain text
router ospf 1
  area 0 authentication                             enables on all ints in area
or per int
int *
  ip ospf authentication
  ip ospf authentication-key CISCO
md5
router ospf 1
  area 0 authentication message-digest
or per int
int *
  ip ospf authentication message-digest
  ip ospf message-digest-key 1 md5 CISCO
regards, mk
please rate if helpful or solved :)
mmanthe
Actually you can use key chains with OSPF with later code releases (I think 15.4 and up). In fact it’s the only way to use SHA with OSPF. Define key chain as normal then implement under the interface
see here: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_ospf/configuration/xe-3s/iro-xe-3s-book/iro-ospfv2-crypto-authen-xe.html#reference_0BFE4845A5E141DEB412864B95B6C57C
Deepak Kumar
As I am aware of the Key chain-linking is not possible directly yo OSPF process. You must define under the interface.
You can make authentication compulsory for all routers in the area using the OSPF process but again key must type under the per interface.
router ospf 1
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
