Linking seperate building networks
esprit1987
Hope you can help...
I have 2 building networks I need to connect and with building 'A' needing to access resources on VLAN 161 in building B. I already have 3 other buildings connecting to building A but on a slightly different setup, so please can you review what I have below and advise if this will work...
The main goal is for building A on VLAN 2 192.168.150.0 \24 to access resource on VLAN 161 192.168.161.0 \24. But in an ideal world have access to all 4 vlans in building B (Vlan 160, 161, 162 and 163)
Please see below my initial config
Building A Catalyst 3560
interface GigabitEthernet0/49
description P2P LINK CSW
switchport trunk native vlan 161
switchport mode trunk
interface Vlan160
description building b management
ip address 192.168.160.1 255.255.255.0
interface Vlan161
description building b CCTV
ip address 192.168.161.1 255.255.255.0
interface Vlan162
description building b ACS
ip address 192.168.162.1 255.255.255.0
interface Vlan163
description building b VCOM
ip address 192.168.163.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.50.1
ip route 192.168.151.0 255.255.255.0 192.168.151.1
ip route 192.168.153.0 255.255.255.0 192.168.153.254
ip route 192.168.160.0 255.255.255.0 192.168.160.254
ip route 192.168.161.0 255.255.255.0 192.168.161.254
ip route 192.168.162.0 255.255.255.0 192.168.162.254
ip route 192.168.163.0 255.255.255.0 192.168.163.254
Building B SG350XG-24F
interface TengigabitEthernet1/0/23
description buildingAuplink
spanning-tree link-type point-to-point
switchport mode trunk ------------------------------This may need to be set as “switchport mode general” when connecting small business switches to Catalyst
switchport trunk allowed vlans all
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
ip default-gateway 192.168.160.1
ip route 192.168.150.0 /24 192.168.160.1
ip route 192.168.150.0 /24 192.168.161.1
ip route 192.168.150.0 /24 192.168.162.1
ip route 192.168.150.0 /24 192.168.163.1
I look forward to your feedback
2 Accepted Solutions
Richard Burts
There are multiple things in this config to address:
- you do not show it so we have to ask is it correct that ip routing is enabled on the switch in building A and not enabled on the switch in building B?
- building A specifies switchport trunk native vlan 161
but building B lets the trunk use the default native vlan
- you show only partial configs so we can not be sure how the vlans are configured in building B and whether there are any vlan interfaces configured on the switch in building B.
- so are we correct that building A will do all routing for devices in building B (including routing between the several vlans in building B - vlan to vlan communication)?
- you have these static routes on the switch in building A
but they do not make sense and certainly are not needed. Each of those subnets is a connected subnet (based on the interface vlan x configured on switch in building A) and you do not need static routes for connected subnets. The switch will route for them automatically. Also what is the .254 address specified in the routes?
- you have some static routes on the building B switch which are puzzling. For one thing you specify a default-gateway on this switch which suggests that it is operating as a layer 2 switch. But static routes only work is the switch is operating as layer 3.
- also these static routes are all for the same remote subnet address but specify different next hop addresses for how to get to that remote subnet
Rick
balaji.bandi
As per your information you have Build A has all the VLAN  "Building A Catalyst 3560" as per the information you have provided.
if you like other VLAN to allow you need to add all of them if this is the trunk using to connect other switch
switchport trunk allowed vlan 160,161,162,163
you need to route here :
ip route 192.168.150.0 /24  to Other switch IP address
Building B SG350XG-24F  - if this switch acting as Pure Layer 2 or Layer3?
create a VLAN 160, 161,162,163
Then allocate the interface to respected VLAN.
you can have ip routing enable
ip route 0.0.0.0 0.0.0.0 x.x.x.x (uplink Switch IP address).
Another question where is VLAN 2 ?
BB
Richard Burts
Rick
balaji.bandi
BB
I am glad that our suggestions were helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
