Load Balance and Failover using EIGRP
cmadiam82
Hi All,
We have this network (please refer to the attached file) which I want to configure loadbalance and failover on the remote site using EIGRP. How can this be done? Please note that links on the remote sites has different bandwidth.
Your help is much appreciated.
cmadiam82
On the remote side router make sure the bandwidth and the delay commands should have the same value on both the wan interfaces.
I have tested on my GNS3, you can find attached the sample configuration for your reference.
Karuppu
Karuppu
Thanks a lot Karuppu!!!
