Difference between T3 going down and Layer3 down.
SACHIN SHARMA
When we asked service provider to do intrusive test on the circuit due to BGP neighbor bounce they have asked this question
They want to know whether T3 link itself went down or BGP layer3 drop has occured.Can anyone explain?
Thnx in advance...
gerald.suiza
BGP can drop even if the physical interface does no go down (T3 interface is down/down or protool down). In these cases it could be that errors are so excessive that the BGP keep alives do not reach the BGP neighbor and cause BGP to drop or there are times that the link is so utilized that it starves out BGP and BGP adjacency drops.
So if the servce provider wants to know if the physical interface went hard down or if ONLY BGP dropped so they have a clearer picture of the issue and so that they know where to start looking for the problem.
gerald.suiza
How to identify whether it is a physical layer drop or only bgp drop.i cannot find any info from "sh log" command.can you give me the trouble-shooting commands to identify the issue.
thnx in advance...
try and see if you have interface resets when you do a sh interface. also i would look for crc's and i would look at the the controller. what kind of serial interface do you have?
It is T3
Serial2/0 is up, line protocol is up
  Hardware is M1T-T3+ pa
   Internet address is xx.xx.xx.xx/30
  MTU 1500 bytes, BW 44210 Kbit/sec, DLY 200 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP, crc 16, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d12h
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/87/256 (active/max active/max total)
     Reserved Conversations 2/2 (allocated/max allocated)
     Available Bandwidth 29621 kilobits/sec
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 3000 bits/sec, 1 packets/sec
     76408 packets input, 4655533 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
              0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     146573 packets output, 26435253 bytes, 0 underruns
     0 output errors, 0 applique, 0 interface resets
     0 unknown protocol drops
     0 carrier transitions
   rxLOS inactive, rxLOF inactive, rxAIS inactive
   txAIS inactive, rxRAI inactive, txRAI inactive
