Load Balance Between 2 Service Providers
tpacjer
I have an ASA and would like to load balance between 2 service providers.
I have 1 metro e link and 1 dsl between seperate providers. Is there some way to load balance between the 2 on the ASA.
akin_lopez
Load balancing effectively to the internet using two ISPs can only be done using BGP.
ASA does not run BGP and as such you can't achieve that with it. but ASA can be used to automatically switch to second link if the main link goes down. pls check
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
Giuseppe Larosa
Hello Jeremy,
if the two links have different speeds as I suppose it is wise to use the DSL as a backup link.
follow the suggestions of the other post for ASA
Hope to help
Giuseppe
