load balance on 2911/k9
teleadmin
Helo,
Is it possivel configuring load balance with three intefaces, in my router with the following features?
I have three ISP, and would like balance the traffic ...
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T1, RELEASE SOFTWARE (fc1)
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1613AH8D
3 Gigabit Ethernet interfaces
1 terminal line
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    EvalRightToUse securityk9
uc            uck9          Permanent      uck9
data          None          None           None
Thanks!
you need at least one more FE or GE interface, for example HWIC-FE or HWIC-2FE
and you can make load balance with BGP (not full view) or 3 static routes if all three ISP the same bandwith
No additional ethernet interfaces are needed, as one can use a switch and VLAN interfaces, or ADSL interface
Also note that not  everyone has BGP or the option of running it.,
