load balance with multi exits on static route?
julxu
Greeting
I have only one default route 0.0.0.0 which configured as static route. I am currently trying to configure multi-homing.
Could I get advice, if I can configure second edge router using static route also, and this router can share the load with current one? I mean without BGP/EIGRP?
Any comments will be apprecated
Thanks in advance
Marwan ALshawi
Yes you can
if you've two static default routes the router will do loadbalancing by default will be per session loadbalancing
which means session to ip x.x.x.x will use next hop 1
session to ip y.y.y.y will use next hop 2 and so on
if this is Internet links you may need to consider nating configurations
also you if you want to look for advanced ios features you may use pfr for loadbalancing with static routes
see the bellow document which wil help you to under stand some features that may apply to your case
https://supportforums.cisco.com/docs/DOC-8313
https://supportforums.cisco.com/docs/DOC-8353
good luck
if helpful Rate
Marwan ALshawi
Yes you can
good luck
if helpful Rate
