Load Balancing between two ISP's
benthomas
Community Member
We are currently running a 7206VXR router with two FastEthernet ports to an ISP via a 1 Meg link and we are in a process of purchasing a second router with the same spec and connect it to a different ISP also via a 1 Meg link. Which is the best way to load balance traffic between the two links? Which protocol must we use, OSPF, BGP,etc...
5 Replies 5
nathan.deane
Level 3
Level 3
It is worth reading about BGP Multi-Homing. Check out this document for a configuration example
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
Not to sure if there are any limitations using per packet / destination load balancing with the connection from 2 ISP's i would not think so
http://www.swcp.com/~jgentry/cisco/cisco-load.html
Nathan
abolfathi_0248
Community Member
i was facing such situation.our company use 2 uplink to Internet via 2 diffrent ISP.we want to loadbalance traffic on both link and increase avalibility of our published servers so that servers be accessible throuth 2 uplinks.we use cisco 2621XM and 3662 for each link and we don't want useing any form of Dynamic routing or BGP.searching cisco website to find such feature come we no result.therefor i use a Linux box for this purpose.Linux kernel have ability to loadbalance (with PBR and equal cost multipath load balancing and NAT/PAT) egress traffic and high avalibility for ingress traffic(if u want your servers be accessible even one of your uplink goes down).it also can detect dead gateway and work fine with your existing cisco routers.
see www.lartc.org (Linux Advance Routing and Trffic control)
abolfathi_0248
Community Member
It may also be worth looking a gateway loadbalancing protocol (GLBP)
This has the ability to share traffic across to connections on multiple routers.
another alternative would be a Foundry / Cisco loadbalancer
jayn
Community Member
Look in OER feature (Optimized edge routing) whiich is available from I think 12.3T.
