Load balancing on 827 router with two ADSL links
lacrimosa
Is it possible to create the load balancing on 827 router with two ADSL links (one ISP or two)? What are the tricks or clues?
spremkumar
Level 9
Level 9
Its very much possible with 2 default routes with policy based NAT if you have deployed NAT in your network.
regds
What means "policy based NAT"? Is it necessary to have policy?
And can I configure two dialers on int ATM0?
I suggested NAT with route-maps assuming you hve 2 pools from the ISP..
In that case you can make use of route maps with NAT statements..
The same is being discussed here under this link.. ..
http://www.cisco.com/warp/public/105/nat_routemap.html
regds
