Load balancing question
vhashrjacksb2
I have 2 T-1's coming into a single 1841 router. On the 1841 I have NAT configured for the internal traffic destined outbound. The router is also running CEF.
My goal is to load share across the two T-1's. Will the following configuration work as desired?
int s0/0
description ISP1
ip addr 10.0.0.2 255.255.255.252
int s0/1
description ISP2
ip addr 172.16.1.2 255.255.255.252
int f0/0
description lan
ip addr 192.168.1.1 255.255.255.0
ip nat inside source route-map ISP1 pool ISPONE overload
ip nat inside source route-map ISP2 pool ISPTWO overload
ip nat pool ISPONE 172.16.1.3 172.16.1.3 prefix-length 28
ip nat pool ISPTWO 10.0.0.3 10.0.0.3 prefix-length 28
route-map ISP1 permit 10
match ip address 1
match interface Serial0/0
route-map ISP2 permit 10
match ip address 1
match interface Serial0/1
access-list 1 permit 192.168.1.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route 0.0.0.0 0.0.0.0 172.16.1.1
Brian
5 Replies 5
Edison Ortiz
Instead of
use
set interface Serial0/0
However, I prefer going with
set ip next-hop [ip at remote router's serial]
Thanks for the response. Since I am trying to load balance between the two T-1's I don't think using the SET statement will work will it? If I use the SET statement it will direct traffic out of that specific interface rather than load balancing between the two.
Thanks for the help but I took a chance and put that config into production and it worked perfectly.
Very nice.
