Load Balancing - using Static Routes (Urgent Requirement)
guruprasadr
Level 7
Level 7
HI All,
Case:1
I have 2 equal cost links from my router for a single destination.
Is it possible to Load Balance using a "Static Route" for these links.
Case:2
I have 2 Unequal Cost Links from my Router for a single destination.
Is it possible to Load Balance using a "Static Route" for these Links.
Note:Kindly give me a Scenario with Cmds Syntax also if possible.
If "Static Route" is not possible means which Routing protocol will help me ! !
Thanks in Advance ! !
Thanks & Regards,
Guru Prasad R
13 Replies 13
smothuku
Level 7
Level 7
HI Guru,
BGP is the best protocol for these kind of scenario.
Case 1: It is possible to load balance if you have 2 equal cost paths to destinations using statice routes.
case2: If you want to load balance with 2 unequal cost paths to destination , better use BGP for load balancing the traffic.
check the below link
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
HTH,
Satish
HI Satish,
Can you please given a Example: for Static Route Load balancing Techniq (for equal cost Links to the same destination).
Eg with Syntax if Possible ! !
Awaiting for your earlier updates. Thanks in Advance ! !
Thanks & Regards,
Guru Prasad R
HI Satish,
Thanks for your Infn.
But, CEF is possible on Cisco 7200, 8000 Series & above Models. I have Cisco 2811 Series Router with 2-FastEth Interfaces.
1.I would like to use Static Route(equal cost links) inorder to Load Balance.
Advice on my 2nd Point:
2.If static Route doesn't work means can i configure the Links as "Point-to-Point" Link for Load Balancing Requirement.
Awaiting for your Answers. Thanks in Advance
Thanks & Regards,
Guru Prasad R
Where did get the idea that CEF is available only on high-end routers?
In fact, it is available on ALL Cisco routers and L3 switches.
Hi Guru ,
2800 router supports CEF
satish
HI Satish,
Kindly confirm me this feature:
CEF support + Per-Packet Load Balancing
CEF Support + Per-Destionation Load Balancing
is availible in Cisco2811 with IOS 12.4(3c)
Awaiting for your Answers. Thanks in Advance!
Thanks & Regards,
Guru Prasad R
If your biggest concern is balancing the bandwidth, you might want to look at something like content server switch/hardware load balancer.
There is even a module that you can put in your 2800 routers http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fb9f.html
Rajeev.S
Hi Guru,
The follwoing IOS supports CEF.
Enterprise :
c2800nm-entbase-mz.12.3-14.T7
c2800nm-entbasek9-mz.12.4-12
c2800nm-entbasek9-mz.12.4-11.T1
c2800nm-entbasek9-mz.12.4-6.XT
c2800nm-entbasek9-mz.12.4-6.XE2
c2800nm-entbasek9-mz.12.4-4.XC6
You are looking for which feature set IOS.
Can you paste sh version output of 2811 router.
satish
HI All,
My Version is:
c2800nm-advsecurityK9-mz.12.4-3C.bin
Kindly Confirm me whether this Supports:
CEF + Per Packet Load Balancing
CEF + Per Destionation Load Balancing
Note:Whether CEF & (Per-Packet & Per-Destination)Load Balancing is a Single Feature (or) two different Features.
ie.,If we have CEF Feature Enabled means can we use Per-Packet & Per-Destination Load Balancing (or) its an Unique Feature.
Awaiting for your Earlier Updates.Thanks in Advance ! !
Thanks & Regards,
Guru Prasad R
Hi Guru,
The following IOS supports CEF on 2811 router.
NOTE: Below mentioned IOS requires 256 Mb of DRAM and 64 Mb of flash(min.)
1.c2800nm-advsecurityk9-mz.12.4-6.XT
2.c2800nm-advsecurityk9-mz.12.4-6.XE2
3.c2800nm-advsecurityk9-mz.12.4-4.XC6
4.c2800nm-advsecurityk9-mz.12.4-2.XA
5.c2800nm-advsecurityk9-mz.12.4-11.T1
6.c2800nm-advsecurityk9-mz.12.4-12
7.c2800nm-advsecurityk9-mz.12.3-11.YZ1
8.c2800nm-advsecurityk9-mz.12.3-14.T7
The IOS which you are using doesn't support CEF.(Let me check it once)
CEF means it is for per-packet and per-destination load balancing.
satish
HI Satish,
Thanks for your Details Infn. We have planning to Upgrade our IOS Version supports CEF Feature.
Can you please provide me a Final Confirmation list of IOS Versions - for 2811 Router supports CEF Feature & Fucntionality.
Thanks & Regards,
Guru Prasad R
hi guru,
you will find all kind of IOS information for perituclar platform and for perticular features...
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regards
Devang
