Load Balancing when multihome to 2 ISP's with Default Routes
borman.bravo
Just wondering what options I have when trying to load share traffic across 2 ISP's from a multihome router that only accepts default routes, the goal is to utilize links from both ISP A and ISP B, any suggestions?
cadet alain
are you using static default routes or BGP learned default routes ?
Regards.
Alain
BGP learned default routes, thanks
jawad-mukhtar
Level 4
Level 4
ip nat inside source route-map fixed-nat interface Dialer0 overload
ip nat inside source route-map dhcp-nat interface FastEthernet0 overload
access-list 110 permit ip 192.168.108.0 0.0.0.255 any
route-map fixed-nat permit 10
 match ip address 110
 match interface Dialer0
route-map dhcp-nat permit 10
 match interface FastEthernet0
See the Links that will help u
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
** Do Rate Helpful Posts**
Jawad
