Load balancing with failover on BGP routes
shyamradhe
Hi every one.
I have a situation like below
We have Router A which is connected to sites B,C & D with mpls via ISP1, in a hub & spoke manner.
Now we are planning to add 1 more ISP2 which will provide connectivity to Site D only for now.
Site A and Site D is on BGP route.
Now My question is If I want to configure Load balance on site A and site D for both ISP what and how it will be ?
notice*- Site A is a HUB location all services Like Internet and Others are running Through Site A only.
"We need to use both ISP at the same time and also a fail over if on link goes down, at least Site D will be reachable."
What will be best Solution for this.. Which feature I can use, Route Policy ? IP sla, HSRP, GLBP , or any thing else.
I Need   an Expert Advice. ?
since you exchange BGP between site A and D, you could use an AS prepend, community string, or origin value setup to achieve load balancing and failover. Check this link (go to BGP topology 4) for sample configurations, or post the configs of both site A and site D routers, so we can put the relevant configurations in there...
http://showipbgp.com/bgp-configurations/cisco.html
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Will the two ISPs have different ASs?  If so, same number of AS hops to D?  If so, you can use the hidden command, bgp bestpath as-path multipath-relax, to allow ECMP.
AS Will be different ... and i think i don't need to do any thing !! in this case Router A  and Router D will Automatically load balance the  traffic and do fail over if one fails .. Right ?
"Fail-over" should be "automatic", using both links, by default, I believe is not "automatic".  I.e. the latter will require some additional configuration.
