load balancing with OSPF
sabeshkhan
I have 2 ADSL links and i need to make a load balancing tecnology with these links. Is this possible with OSPF?
If yes plese help me to set up the routers.
5 Replies 5
Lei Tian
I think you need give bit more information before anyone can make suggestion. Where do the DSL links connect to? What devices are behind the DSL router? Are you running OSPF inside?
HTH,
Lei Tian
the ADSL links were connected to a cisco 871 routers and then one uplink is going to a switch because we cant plug the both uplinks to the switch the other link is not using so i hope to put a cisco 1841 router inbetween the 871 and the switch so I need to make a load balancing using the cisco 1841 is this possible?
Because I need to use the both links.
vasanth_k08
Load sharing or load balancing....?
load balancing
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As long as OSPF "sees" multiple paths with same cost, OSPF will equal cost load balance.  Kind of physical media doesn't matter.
