Load balancing with use of router 881.
KR SHAH
I have two MPLS line and i want load balancing with the help of CISCO router 881. is it necessary that i require two router on both location.? if one location have firewall and one location have cisco router 881 then can i do a load balancing or i require two router each on both location ? What are the basic requirement that i need.
Kuntal
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
An 881 should be able to load share across multiple ports.  Many routing protocol support ECMP, including BGP, but you need "special" hidden/secret commands to enable.  EIGRP also supports unequal cost load sharing.
If an 881 supports OER or PfR, those too will do unequal load sharing, dynamically.
