ospf adjacency not forming over gre tunnel
codflanglers
Trying to get ospf to form an adjacency over a gre tunnel but it's not working. On the hub it's showing as state INIT, but nothing on the spoke.
Spoke debug ip ospf adj, packet and events shows nothing. Hub doesn't show much either. Any ideas?
HUB
interface Tunnelxxxx
 bandwidth 1000000
 vrf forwarding xxxx
 ip address x.x.x.x 255.255.255.248
 no ip redirects
 ip mtu 1400
 ip nhrp map x.x.x.x x.x.x.x
 ip nhrp network-id xxxx
 ip tcp adjust-mss 1360
 delay 10
 tunnel source <interface>
 tunnel mode gre multipoint
 tunnel key xxxx
 tunnel path-mtu-discovery
 tunnel vrf xxxx
 tunnel bandwidth transmit 100000
 tunnel bandwidth receive 100000
end
router ospf xxxx vrf xxxx
 router-id x.x.x.x
 passive-interface default
 no passive-interface <interface>
 network x.x.x.x 0.0.0.15 area 0
SPOKE
 bandwidth 11131
 vrf forwarding xxxx
 ip address xxxx 255.255.255.248
 no ip proxy-arp
 ip mtu 1400
 ip nhrp map xxxx xxxx
 delay 10
 tunnel destination x.x.x.x
 tunnel key xxxx
end
router ospf 1 vrf xxxx
 router-id xxxx
 network x.x.x.x 0.0.0.3 area 0
you need a command  for both hub and spoke to operate ospf properly on interface tunnel 0:
 ip ospf network broadcast
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/43068-dmvpn-gre-ospf.html
Kazim Abbas
8 Replies 8
minhda
Spoke router missing tunnel vrf under gre interface.
Minh
Does that matter for OSPF? The tunnel is up and traffic passes over it (ping either end through it).
Without this command, ospf will only use interfaces on global routing instance.
That vrf is a different vrf id than the one already mentioned on the tunnel under vrf forwarding. OSPF already has the vrf mentioned on it.
On the spoke, Can you post output of show ip ospf 1 int brief
hostname#sh ip ospf 1 in bri
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Tuxxxx      1     0               x.x.x.x/29     8     P2P   0/0
Vl1          1     0               x.x.x.x/30     1     BDR   1/1
Please run below command on both end router.
Kazim Abbas
