Load Balancing..
Mavrick25
Level 4
Level 4
Is it better to load balance with a BGP or IGP?
Is it better to have BGP advertise the default of the IGP?
MAV
Giuseppe Larosa
Hello Paolo,
1) load balancing is actually done by CEF on the forwarding level.
IGP have usually maximum-paths 4 so they can load balance up to 4 equal costs path by default.
BGP can load balance but by default it has maximum-paths 1
two options are possible:
using a loopback to perform load balacing by recursion (the BGP session is only one but BGP next-hop is reachable through two or more links)
or
inside router bgp you increase maximum-paths with an explicit command
It depends from your scenario
2)
if BGP is enabled in all routers you can choice to send a default route in BGP but if it isn't you need to propagate a default route in your IGP
Hope to help
Giuseppe
