Load sharing and fail over
Lavanholy
I have a Cisco1841 router ,which has 2 fast ethernet ports ,Then I have loaded one 4 switch port module,I am going to have the 2 DSL ISP connections,2 DSL modems will be terminated to each of the ethernet interface.
Now I have servers connected to teh 4 switch port module,
Can I configure load sharing and fail over between the two ethernet interfaces?
Can you give me a sample configuration.
Thanks and Regarsd,
S.Venkataraman
5 Replies 5
spremkumar
Level 9
Level 9
Hi Venkat
Have you taken the DSL connections from the same ISP or is it from 2 different ISPs ?
I would suggest to check out for higher capacity single pipe or use the links on failover scenario instead of load balancing.
If you do load balancing on the 2 DSL links you will be able to do the outbound load balancing and also you may not get desired/proper load balancing ..
On the inbound load balancing you may not have the traffic evenly getting distributed between your links..
regds
Hi Prem,
Thanks for the info.If suppose I have same ISP,in that case can I be able to configure the load sharing and failover for both inbound and out bound?
Thanks and Regards,
S.Venkataraman.
I am interested doing something very similar with a 2811. Can you divide the switching ports in to to VLANs and route packets from the FE ports to the devices in the switch?
john.castanares
I have already done this setup recently using "same ISP". This is possible to configure the load sharing between two wan link as long it is same ISP by using "per-packet scheme"
Pls. see the sample config below:
inter loop 0
ip address 1.1.1.1 255.255.255.255
int fa0/0
ip address 2.2.2.2 255.255.255.252
description "link 1"
ip load-sharing per-packet
int fa0/1
ip address 3.3.3.3 255.255.255.252
description "link 2"
ip route 0.0.0.0 0.0.0.0 4.4.4.4 (note: next-hop is the loopback of ISP)
ip route 4.4.4.4 255.255.255.255 fa0/0
ip route 4.4.4.4 255.255.255.255 fa0/1
Note: you are required to coordinate with the isp since they need also to configure a loadbalancing from their side also.
Hope this will help you.
-john-
Hi John,
Thanks,I will try this.
S.Venkataraman.
