load sharing between 2 ISPs
muhanadjamjoum
please advise...
i am to buy a cisco router that would enable me to share a 2 leased lines (wic-1T modules) connected to 2 different service providers. is there a solution to do that without additional setup from the provider's side? maybe CEF??? what router would be most suitable?
thisisshanky
Level 11
Level 11
Running BGP ? or just default routes ? Easy way is to run default routes to both ISPs and use CEF. You dont get inbound load balancing with this setup. You will need BGP in that case.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
