MPLS with Frame-Relay, GRE, 3DES, DMVPN.
jteixido
I'm currently a frame-relay customer that is considering going MPLS. With frame-relay I am currently running DMVPN with 3DES and GRE.
Is there anyone here an enterprise MPLS running a similar configuration? I can peer through an MPLS cloud?
mheusinger
Level 10
Level 10
Hi there,
there should be no real issue as long as all traffic is IP. Basically a MPLS VPN looks to the customer like ONE big IP router. It takes IP packets and forwards them to another interface and it takes routing updates and sends routing updates out through other interfaces.
Hope this helps
Martin
