loading IOS greater than 33MBs fails
mizoran78
Hi all,
My problem is the following. I have 2811 router with 256MB of RAM and 64MB of flash memory, loaded with IOS 12.4(3g). It has CME 3.3 up and running and generally it works OK.
But my problem began when I wanted to upgrade IOS with newer IOS due to upgrade from CME v3.3 to v4.x.
Namely, when I started copying a new IOS image from tftp server to router's flash, it failed.
Everything was normal (with copying) when it started to load, but when it was about to finish (98% was loaded to flash), suddenly it changed exclamation marks "!" for "O" letter (like this ...!!!!!!!!!!!!!!!OOOOOOOOOOOO....) and that was the end of process.
Is there any solution or explanation for this?
TIA
Zoran Milenkovic
Mark Yeates
Level 7
Level 7
Zoran,
What TFTP server are you using? Some TFTP servers have size limitations. I found using tftpd32 a good server that doesn't have this size limitation. You may want to give it a try.
HTH,
Mark
6 Replies 6
Mark Yeates
Level 7
Level 7
Zoran,
HTH,
Mark
As Mark mentions, some TFTP servers have a file size limitation; often 32 MB.
Another alternative is to use FTP.
Hey Mark,
You were right and the TFTP was the guilty one!
Thanks to other guys also! Tftpd32 works just fine.
BR
Zoran
Leo Laohoo
Try TFTP32. I know it worked for me.
http://tftpd32.jounin.net
Hey guys!
Thanks a lot for the great hint! I will try out the recommended TFTP sw and come back to you with the results.
BR
Zoran
Thanks for the rating Zoran.
