Local connect on ASR920
cedrictabary1
I am trying to do local connect on an ASR920 running latest IOS
interface Gi0/0/20
service instance 10 ethernet
encapsulation dot1q 10
rewrite ingress tag pop 1 symmetric
interface Gi0/0/21
service instance 20 ethernet
encapsulation dot1q 20
connect TEST Gi0/0/20 10 Gi0/0/21 20
One of the vlan interfaces is unable to perform vlan rewrite
%CONN: invalid segment 1
%CONN: Invalid Command
I am also trying to use the l2vpn syntax, configuration is set but with an error log and no traffic flows
l2vpn xconnect context TEST
member Gi0/0/20 service-instance 10
member Gi0/0/21 service-instance 20
%FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: SIP0: fman_fp_image:  atom_xconnect xid 0x10, ifh 16, dirty 0x1, state 0x2 download to CPP failed
I also tried simple connect of physical interfaces :
interface GigabitEthernet0/0/9
 no ip address
 negotiation auto
interface GigabitEthernet0/0/10
 no ip address
 negotiation auto
connect TEST GigabitEthernet0/0/9 GigabitEthernet0/0/10
%FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F0: fman_fp_image:  atom_xconnect xid 0x10, ifh 16, dirty 0x1, state 0x2 download to CPP failed
So I wonder if ASR920 does not support local connect or if I am doing something wrong ?
11 Replies 11
k_jackson
What is the IOS XE version that you are using?
Also, could you please share the output of show platform from the router.
KJ
Here are the version and platform :
Cisco IOS XE Software, Version 03.16.00.S - Extended Support Release
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.5(3)S, RELEASE SOFTWARE (fc6)
Chassis type: ASR-920-24SZ-IM
Slot      Type                State                 Insert time (ago)
 0/0      24xGE-4x10GE-FIXED  ok                    1d17h
R0        ASR-920-24SZ-IM     ok, active            1d17h
F0                            ok, active            1d17h
P0        ASR920-PSU0         ok                    1d17h
P1        ASR920-PSU1         ps, fail              1d17h
P2        ASR920-FAN          ok                    1d17h
Slot      CPLD Version        Firmware Version
R0        15033124            15.6(1r)S1
F0        15033124            15.6(1r)S1
I think you are not meeting the minimum requirements to run local connect on ASR920. the evc local connect support is supposed to be from 15.6(2)S release which i dont think is the case here.
Also, i think you will need ASR920 with RSP2. Could you please verify the show inventory to see if you are having RSP2.
Vinit
--Vinit
Here is the show inventory with serial numbers stripped.
a920-1-gs-par#show inventory
NAME: "Chassis", DESCR: "Cisco ASR920 Series - 24GE and 4-10GE- Modular PSU and IM"
PID: ASR-920-24SZ-IM   , VID: V01, SN:
NAME: "Power Supply Module 0", DESCR: "ASR 920 250W AC Power Supply"
PID: ASR-920-PWR-A     , VID: V01, SN:
NAME: "Power Supply Module 1", DESCR: "ASR 920 250W AC Power Supply"
NAME: "Fan Tray", DESCR: "ASR 920 Fan tray"
PID: ASR-920-FAN-M     , VID: V01, SN:
i guess i mis-interpreted. RSP2 is seperate. ASR920 has a diff architecture than ASR903.
--Vinit
Vinit Jain
I think the support for local connect on ASR920 starts with 15.6(2)S release. thus it should not work before that release.
Vinit
--Vinit
Hello Vinit,
latest download is asr920-universalk9_npe.03.16.00.S.155-3.S-ext.bin
15.6(2)S is not yet available ?
Cédric
Hello Cédric
yes, thats what i understood based on my research internally.
I will check further and let you know if its supported or not.
Vinit
--Vinit
Hello Cédric
It is confirmed that evc local connect will be supported from XE release 3.18 . the version you are running is XE 3.16. Since 3.18 is not released yet, you will have to wait for sometime to use this feature.
Vinit
PS: Please mark the question as answered if your query has been answered.
--Vinit
Hello Cédric
Could you please share the requirements for doing a local connect on ASR920.
i can check if we can find an alternate solution to your problem.
Vinit
--Vinit
I have several needs :
- connect two physical ports (as a media converter) for a customer
- connect physical port to service instance on another port
- connect a service instance to another service instance (vlan rewrite) between two ports or same port.
I can do all of this with bridge-domains but this is not completely transparent : uses mac addess tcam, needs l2protocol tunnel.
Thank you
Cédric
