Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco 7200VRS module 4ME1-BAL configuration document
yang yang
HI ALL
Does any one have or know where i can find the cisco 7200VRS module 4ME1-BAL  configuration documnet. Or does some one know do this module support E1(DDN)/CE1(time slot).
I am having problem to make the connection up
the SP setting is:
Under MAIN LINE : (TS 24-31)
ACCESS PATH : E1 type
CRC4 OFF
Clocking : Network clock
Format : CCS
Code : HDB3
our side config:
controller E1 1/0
 framing NO-CRC4
 channel-group 23 timeslots 24-31
interface Serial1/0:23
 description Primary
 no cdp enable
other side config: 4ME1-BAL
interface Serial3/0
bandwidth 512
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ntp disable
timeslot 1-8  (must "no" this for line interface to come up but protocol still down , have try 24-31 the line interface was down)
crc4     (have try no this but not do much good)
ts16    (have try no this but not do much good)
serial restart-delay 0
no cdp enable
0 Replies 0
