Local Log Issue on Cisco 6509
jdavid6568
I am trying to determine a problem with flapping interface on a router  not showing up in log buffer if Cisco IOS. I've included the config on  the switch that pertains to the logging and can't seem to figure what is  going on. The SNMP trap is being sent to our Central Management trap  server and that is reporting the interface flapping but the flap doesn't  show up in the log messages. Any ideas?
hstir1#sh int desc | inc 8/33
Gi8/33 up up
Gi8/33 down down
Gi8/33 up up
Gi8/33 up up
Gi8/33 up up
(no mention in local logs)
however Zenoss see's Flapping:
Start Time: 2012/07/09 17:30:58.000
Stop Time: 2012/07/09 18:00:01.000
Count: 30
Message: Flapping (38 x last hour) - Link Down ( GigabitEthernet8/33 )
Owner:
interface GigabitEthernet8/33
switchport
switchport access vlan 833
switchport mode access
no ip address
speed 100
duplex full
logging source-interface Loopback0
logging x.x.x.x
logging x.x.x.x
logging x.x.x.x
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
Console logging: disabled
Monitor logging: level debugging, 10 messages logged
Buffer logging: level debugging, 131414 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 131510 message lines logged
Logging to x.x.x.x, 130621 message lines logged
Logging to x.x.x.x, 97029 message lines logged
Raju Sekharan
Configure
"Logging event link-status" under the physical interface
Thank you
Raju
paulstone80
Level 3
Level 3
Have you got the command logging buffered xxxx configured?
HTH Paul ****Please rate useful posts****
sure do......
logging buffered 65535 debugging
